AxisVM x7 - NEW FEATURES IN THE BASIC PACKAGES
edited January 31 in CAE
Cross-sections
Parametric Z section
A parametric Z section is available in the cross-section editor
Elements
Additional option for domain eccentricities
When setting the eccentricities assigned to domains, the user can specify whether they should be taken into account in the calculation or only included in the drawing as a visual effect.
Elements
Spring characteristics of edge hinges
Allows for the definition of edge hinges with spring characteristics, different static and vibration stiffness, and complex/complex nonlinear behaviour modelling.
Modelling
Automatic calculation of the shear center of the structure
The program automatically calculates the shear center of the levels, which are displayed when the model is built.
Loads
Automatic self-weight load case
A new self-weight load case is available, which automatically includes the self-weight load of all structural elements in the model.
Loads
Merging loads
Allows for merging separate load cases from the same group into a single load case.
Buckling
Buckling analysis for selected model parts (NL package)
The entire structure is included in the analysis, however, the elements not included in the examined parts only act as elastic supports. As a result, only the buckling modes of the selected elements appear.
RC design
Cutting of shear force peaks over columns
The program cuts the shear force peak above the columns when displaying the stresses of the surface elements.
rc_desgn_cutting_peakspng
Documentation
Documentation of material and cross-section data
The documentation of the material and cross-section is refreshed in a new, clear structure and is available in the Report maker when creating PDF files or printing.
Analysis
Analysis parameters in the Tables
The initial parameters of the nonlinear/vibration/dynamic analysis performed are summarized in the Tables.
